April 28, 201115 yr comment_520219 hey guys the torsion bar(i think thats what its called!? the bar that goes between the roof and roof lining to hold the tailgate open) in my tailgate is F***ed. I'm looking at putting some struts in. any suggestions? or should i just get some made up? :hmm: Report
April 28, 201115 yr comment_520279 Is it definitely a torsion bar? Because the earlier rolla's had coil tension springs. Report
April 29, 201115 yr Author comment_520375 Is it definitely a torsion bar? Because the earlier rolla's had coil tension springs. It's a long thin bar from one side of the roof to the other. It clips into two U shaped plastic clips which are on the hinges. One of the hinges is snapped (was when I got the car) and the tailgate os lop-sided from attempting to fix it :-s Report
April 29, 201115 yr comment_520455 you should be able to get some struts to work, you'll have to watch a few things though; make sure where you mount the struts is reinforced, weld in some plate if possible make sure you use strong enough struts, struts are rated in newtons, the higher the newtons the stronger force the strut applies over its action make sure you allow enough room between where you mount on the car and where you mount on the tailgate so that when shut the strut can collapse well, and that it reaches far enough to open the gate to a suitable height. With some careful measurement you can make it work Report
May 4, 201115 yr comment_521778 Is it definitely a torsion bar? Because the earlier rolla's had coil tension springs. Yep, definatly torsion. Seen boot springs on a KE30? 2 spring steel rods. secured at one end, the other is attached to the hinge on the other side. Pics for reference. open closed Report
May 5, 201115 yr Author comment_521949 THATS IT!! :D but the small metal arm which holdens the bar, is badly bent on my passengers car and the plastic clips have gone brittle and fallen off. i figure it would just be easier to fit struts than search for the parts to fix it :blinks: Report
May 5, 201115 yr comment_521960 hey guys the torsion bar(i think thats what its called!? the bar that goes between the roof and roof lining to hold the tailgate open) in my tailgate is F***ed. I'm looking at putting some struts in. any suggestions? or should i just get some made up? :hmm: Try mitsubishi colt or series 2 hyundai excel. they bolt to the frame and were a great replacement on my ke50 liftback. Report
May 9, 201115 yr comment_523007 I reckon you'd be better off fixing your existing setup OPH13, struts are a bit trickier than you might realise (to do properly). Edited May 9, 201115 yr by philbey Report
