October 31, 200520 yr comment_80346 Hey everyone, I have a ke70E with a 4kc engine. Attached to the 4kc is a two barrel webber carbie. So the problem is when increase the throttle slowly the revs go up normally but when you plant the foot the revs drecrease severely then increase like normal. So yeah just wunderin if anyone knows whats goin on. Thanks. Report
October 31, 200520 yr comment_80415 secondary progression jet may be too big/ small it's up by the top plate, there's one for each barrel Report
November 1, 200520 yr comment_80470 i'd say to rich. most webers are jetted to big for a k series. i would assume it is a 32/36 DGV as well. usually if it is to rich and you plant your foot it will bog down, if you then instantly lift off the engine will pick up. Report
December 1, 200520 yr comment_84998 i'd say to rich. most webers are jetted to big for a k series. i would assume it is a 32/36 DGV as well. usually if it is to rich and you plant your foot it will bog down, if you then instantly lift off the engine will pick up. I'm a bit late but couldnt it be the vac on the advance on the dizzy? either not connected or not working properly? have u solved the problem yet zeel 101? Report
