June 6, 201115 yr comment_529933 Gday fellow rolla club members. my family just brought a 323 astina 1992 it is idling really low and doesnt like pulling off and seems to starve of petrol and then comes to life after around 2000 rpm i have checked the transmition and its fine. i am convinced it is to do with either the injectors, a sensor or the fuel pump. sorry for being so vague and ideas what it could be and what to check thanks in advance Harry Report
June 6, 201115 yr comment_529943 As it's idling low and running lean have you checked the timing? Report
June 6, 201115 yr comment_529946 It shouldn't be fuel supply as it uses less fuel at low revs than high. So the pump shouldn't be the culprit, or a dirty filter blocking up. Maybe the air mass sensor, whatever they're using is dirty and not reading correctly. Are the plugs all clean and looking the same? Gaps not too big?? Its probably going to be fastest to get a garage to diagnose it, epecially if it has any sort of on-board diagnostics. Report
June 8, 201115 yr Author comment_530520 I havent had time to check the timing, as i don't have a timing light to do it properly i recon its the sensor will check it out when i don't have work thanks fellas. Report
June 11, 201115 yr Author comment_531196 found out today, a leed had split, and wasnt working :( fml Edited June 11, 201115 yr by ae95- wagon kid Report
