June 30, 201115 yr comment_536469 Hey, in my ke70 i have a 5k block and a 4k head, i want to put them together... do i need to use a 4k head gasket on the 5k block or 5k head gasket, when bolting them together? the bores are smaller on the 4k head, so it will overhang the bores... but the 5k head gasket will fall a little bit short of the bore? probably a simple answer but need advice, hope this isnt confusing :bash: Report
June 30, 201115 yr comment_536471 use the 5k headgasket as the bore is larger than a 4k. its logically but correct me if I'm wrong Report
June 30, 201115 yr comment_536472 not as simple as just bolting it on bro goto change or the rocker gear pushrods lifters everything Report
June 30, 201115 yr comment_536528 Which pistons and what is the compression ratio going to be?? Report
June 30, 201115 yr comment_536530 Assuming you've worked out all the above stuff, you want the 5K gasket. Otherwise you'll be blowing the gasket all the time as the firing rings will be far too close to the action. Report
