Hi.I need to replace the door window rubbers (that the glass slides up and down in) on my AE71 wagon.Does anyone know where to get them in syd or should i get a length of generic and cut to fit myself?Also,is there a way of adjusting the bonet hinges?Mine sits slightly below the quarter panels at the back,would preffer it sat slightly above.Any help would be much apreciated.
Sounds like you mean the Bailey chanel. If you have Clark Rubber (or similar) over there they should have it on rolls, easy as piss to change :)
Just take a piece in to check the width.
sw :yes: eet,thanks.
should have some round rubber things under the bonnet on the gaurds to lift the front of the bonnet up.. if the rear is sitting to low than you can adjust it by losstening the two bolts holding the hinge to the bonnet and adjusting it till it sits right.. if its extreme than you can 'slot' the holes.
thanks.i'll be playing with that tomorrow too.:dance:
