No Power To Ke70 Coil..
Hey guys...
I'm currently wiring up my 4age conversion into my ke70...
I have extended the positive and negative wires onto the opposite side as the dizzy is on that side...
my problem is that when I put a test light on them and turn the ignition on i get no light turning on... hmmmm
Is there a possibility that the ignition relay or fuse is broken? or i currently have my dash out.. could there be a connection in the wiring loom/harness that is disconnected at present?
Any help would be appreciated!
Could be a lot of things... Welcome to the world of engine conversions!
Do you have a wiring diagram of both cars? The whole AE86 workshop manual is up on the web, and I found the KE70 wiring diagram up there somewhere too. I have them lying around I think.
Once you have both you can figure out where they join up, which won't be too bad if the 4AGE is still on carbs
Yea its still on carbs...
I'm just guna trace the wires back and see how i go!
Cheers for help!
