3K Gapless Rings
hey all as the topic says after some gapless rings to suit 3k
60thou oversize can't find any thanks for your help
why would you want gapless rings?
why not ;)
you don't need them normal rings are better
why not ;)
Because gapless rings are normally atleast twice the price of normal rings. But if you can justify the difference in price then go for them. But from experience(I have em in my 5k) if everything isn't perfect it might breath pretty heavy(i think it rattled a bit when the injectors were too small and lost top ring tension)Not sure but think mine are "total seal".
"Pacific engine parts" can convert your second ring to gapless. Or most speed shops that deal with "total seal" should be able to help. You could even try a different engine. But don't forget ring widths and radial depths can change a heap from engine to engine.
Stu.
Edited by kickn5k
Stu.
what he said they never seal properly and normal rings just work better they can adapt better to the bore when it flexes every time there is combustion
uhh cheers people, but does anyone no where i can get some from? the price doesnt matter
they prob don't exist to fit 3k 60thou over
just get the pistons coated until there is a 0.000001" gap between piston & bore and forget about rings all together.
