Coolant Leak
Hey,
I have a 1997 conquest. I changed the upper and lower radiator hoses a few months due to leaks back but there seems to be a new leak. I believe that it is coming from the small hose which sits near the power steering fluid. I am not sure what this hose is called. It is about 5cm long.
Is there another hose which is close to the one that I described above that is tucked away from visibility when looking into the engine bay which could also be the culprit?
does it leak all the time or only when running??
Sometimes with these things you need to get the torch out and keep a close eye on it. You can usually get all those hoses from repco and what not.
Yeah it leaks all the time. Would you happen to know what this hose is and what it connects too? It will just make it easier when i go to buy a new one from bursons.
just take the old hose in and show the guys at bursons and hopefully they will sort you out with one similar.
Or evan take your car in. They should know what there looking for.
Edited by xr8racer
Get a small piece of mirror or something and a torch and go for gold, never fails to find things :)
