October 25, 201114 yr comment_562558 will this weber manifold fit straight onto my 4k ke70 engine, it's all stock so far, quick answers a good answer :) thanks Report
October 25, 201114 yr Author comment_562559 here's a pic http://item.mobileweb.ebay.com.au/viewitem?itemId=270791758802&index=12&nav=SEARCH&nid=81837215354 Report
October 25, 201114 yr comment_562561 Yes it will fit, BUT (and this may not be relevant) you could run into issues with the carb fouling on the standard exhaust header. With twins on my old 4K the pump linkage hit the hotbox. Report
October 25, 201114 yr Author comment_562588 what if I had the weber 32/36 carby, then would I still run into problems with the weber manifold? thanks heaps Report
October 26, 201114 yr comment_562701 That manifold is designed for a side draft. A 32/36 is down draft. Report
October 26, 201114 yr Author comment_562702 so what would be a good carby, manifold, extractors upgrade be?? for my stock 4k motor?? Report
October 26, 201114 yr comment_562703 Buy coby extractors. I can get them for 150 nzd. Use standard inlet mani and 32/36 adapter 50 nzd and 32/36 weber. That would be the cheap way. If you wana go expensive go side drafts. SU's can work to. Depends how much you wana spend. Report
October 26, 201114 yr comment_562742 Yeah i've got the 32/36 Weber setup it goes fine on standard manifold with small adaptions. That first side draft manifold looked like it would put the carby's close to the strut tower aswell, I'd Rather a big C flow ram manifold kinda like the 4k-e fuel injection manifold. You'll get higher response with more ram. Report
October 26, 201114 yr Author comment_562770 cheaper way for sure, so coby extractors and a 32 36 weber and adaptor will go onto my 4k without any troubles?? cheers Report
October 26, 201114 yr comment_562817 Yeah. you'll just need to get it a bit of a tune up and it'll go good. Report
