October 25, 201115 yr comment_562639 ok i have a 5 speed gearbox that has a ke70 rear housing but i am unsure of the front half what model its from. Its not the same as a ke55 or a ke70 as i have both of those 5 speeds and the bolt pattern for the bell housing is different. The bellhousing has a flat section at the very top with a bolt hole. Is this pattern to suit a 3k? Did they come out 5 speed? Any help would be good. Thanks Chris Report
October 25, 201115 yr comment_562640 I believe 3k's did come with 5speed gearbox's. could be a starlet box? Report
October 29, 201115 yr comment_563332 Photos would help a lot if you can get them. I don't know about the early starlets but the ke10 - early ke30 only had the 4 speed. Report
October 29, 201115 yr comment_563359 It could be a 5 speed gearbox from a ke55 liftback which was mated to a 3k, both were standard kit. Report
October 30, 201115 yr Author comment_563469 i will have to take pics so people can see the differences thanks Report
