November 30, 201114 yr comment_568994 hay guys ive just got a silvertop 20 v. for my 101 . will. the 4afe gearbox bolt onto my 4age with out a problem ? or will the fly wheel and clutch get in the way ? please let me know asap thanks Report
November 30, 201114 yr comment_569006 The pressure plate only hits if you have the 220mm clutch, measure the flywheel and clutch assembly for the 4afe and then do the same for the 20v. Report
November 30, 201114 yr comment_569024 The pressure plate only hits if you have the 220mm clutch, measure the flywheel and clutch assembly for the 4afe and then do the same for the 20v. It should bolt up. MY C160 box from a 4afe corolla g6r I am using on 4age tvis bolt up with no problem. 4afe clutch kit it 212mm Edited November 30, 201114 yr by speng g6r Report
December 1, 201114 yr Author comment_569037 thanks guys now all i need to do is measure the clutch size. their is 2 different sizez. 200 amd 215 Report
December 1, 201114 yr comment_569113 It should bolt up. MY C160 box from a 4afe corolla g6r I am using on 4age tvis bolt up with no problem. 4afe clutch kit it 212mm Obviously he is asking if the 20v clutch and flywheel will fit, if he was using the 4afe (which he can't) then he would not have a problem. Report
December 1, 201114 yr Author comment_569185 sorry trev I'm confused I'm asking if my 4afe gearbox will bolt up to my 20 v engine ? Report
December 2, 201114 yr comment_569226 sorry trev I'm confused I'm asking if my 4afe gearbox will bolt up to my 20 v engine ? Yes it will, all 4a use the same bolt up pattern the c160 box that comes on levin bzr is what toyota use in corolla g6r uk spec on a 4afe engine. I now got that box bolt onto a 4age 16v. Report
December 2, 201114 yr comment_569240 hay guys ive just got a silvertop 20 v. for my 101 . will. the 4afe gearbox bolt onto my 4age with out a problem ? or will the fly wheel and clutch get in the way ? please let me know asap thanks The pressure plate only hits if you have the 220mm clutch, measure the flywheel and clutch assembly for the 4afe and then do the same for the 20v. It should bolt up. MY C160 box from a 4afe corolla g6r I am using on 4age tvis bolt up with no problem. 4afe clutch kit it 212mm Obviously he is asking if the 20v clutch and flywheel will fit, if he was using the 4afe (which he can't) then he would not have a problem. sorry trev I'm confused I'm asking if my 4afe gearbox will bolt up to my 20 v engine ? If there was a problem with the gearbox fitting then I would have said so but instead I said only if it has a 220mm clutch. The 4afe flywheel will not work as it is only 6 bolt, I am assuming you are trying to bolt the gearbox upto the 20v which already has a clutch and flywheel on it. Yes, just go bolt the f*&king thing up, if the clutch hits then shit happens. Report
