Kezzar Posted December 19, 2011 Report Share Posted December 19, 2011 (edited) Hey guys and girls i recently got a 34ADM DGEV weber from a XF for free from a work mate, i plan on rebuilding it, yes i know, its pretty big carb for a stock 4k, but obviously i plan to tune it, but so far looking for recommended jetting for a 34adm suiting 1300cc engine is very hard, so i am referring to what jets people use to tune 32/36 due to the fact they are quite identical carburetors and have the same jets. These are the jets I've summed up, I'm looking at ordering these. Primary main jet = 125, Air corrector = 180, Emulsion tube = F50, Idle jet = 55 Secondary main = 130, Air corrector = 195, Emulsion tube = F66, Idle jet = 50 please help through opinions and Jets you used or even some helpful information. thanks, kezzar :D Edited December 19, 2011 by Kezzar Quote Link to comment Share on other sites More sharing options...
Evan G Posted December 19, 2011 Report Share Posted December 19, 2011 putting a weber from a 4L anchor on a 1.3L isnt gonna work. Quote Link to comment Share on other sites More sharing options...
Ella Posted December 19, 2011 Report Share Posted December 19, 2011 jetted nicely they work just as well as a 32/36... Quote Link to comment Share on other sites More sharing options...
Kezzar Posted January 1, 2012 Author Report Share Posted January 1, 2012 thank you ella, i went to J&c autos and they said i can get it fully dyno tuned to its full potential, they said it will tune up nicely and charged about 250$ for tuning it. Quote Link to comment Share on other sites More sharing options...
Ella Posted January 3, 2012 Report Share Posted January 3, 2012 thats a good price for a tune Quote Link to comment Share on other sites More sharing options...
Jaydnisevil Posted February 29, 2012 Report Share Posted February 29, 2012 Its difficult.. Iv turbocharged my 4k and used a 34 webber but to get the mixtures where I want them iv had to put a 165 Primary and solder the air corrector and re-drill to 100. I'm running 13-15psi at the manifold, its a good carbie once set up right. Mine is still not perfect but its much better. I found in experience and speaking to a few tuners (As well as Webber performance Australia), being such a big carby you will struggle to suck fuel out of the secondaries if you snap the throttle open at low rpm. Which is exactly what was occurring. Itd just lean out and bog down. It just does not have enough airflow to draw the fuel in, I actually disabled my secondaries because it was causing problems. Iv nearly got it 100% mixture wise, just need a dyno to test over a wider range. Might need to tinker with the float level. The main advantage is there are tonns of books on them given they were used in the XF. Quote Link to comment Share on other sites More sharing options...
