i have just brought a ke 70 and plann on doing an sr20de conversion, id like some guidence and id like to know 100% everything i need
at this stage i only have the engine,box and loom!
if you could help me out would be a grate help
Someone on ae86drivingclub.com.au sells bolt in kits for SR20 into ke70/ae71, but to start you will need AE71 xmember, pedal box, possibly gearbox xmember too, then there's bigger brakes, bigger diff and lots of other little items.
so i couldnt use the factory pedal box? is just want to get it in and running at the moment, its not going to be a track car..
When putting a 4A into a KE70, people will use either an AE86 or AE71 engine crossmember, so I'd assume that you would need to get something custom made (could be a kit or something out there).
You would most likely need the hydro clutch setup. As mentioned, the KE70's have a cable clutch, whereas most more modern things will use a hydraulic. These used to be around $80-$100 each, though now people are asking (and getting) upto $250.
My advice (and the advice off almost everyone else on the forums) would be to find an existing build thread where someone else has done the conversion (as it's fairly common) and see what they have done. This will also let you find out all the possible pitfalls etc.
  • Upvote 1
