How Does The Ajps Lock Spacer Work?
G'day, its probs a stupid question, but i don't understand how the lock spacer works, cheers glen haha
When you fit it you essentially make the rack longer as the lock spacer is small enough to slide into the housing and give it more travel, when you fit it you rotate the wheel and centre it by going lock to lock and halving it which is now different to your original wheel centre.
You will now have more length on either side of your rack head so even though you straighten your wheels up with an alignment, when you turn your wheel there will be more length behind the pivot (rack end) giving you more lock.
I hope this is clear enough for you.
i deleted what i just wrote because it was stupid, i just saw a pick of one installed and now i get it, it basically spaces the stopper out further so the rack can travel further lol, i feel stupid. :D
Edited by glenpos
as there are 3-4 teeth that arent used, without the lock spacer, having the spacer your using all of them, guy on DC used to make more teeth hahaha
