Finally finished the back of the car. including boot, lid and back below the bumper. Next thing to tackle is that humongous, hole in the side, I'm thinking very slow amounts of bog, over a couple of days. ?
Ill chuck a few more pics up. - any qu's just ask?
Re the large hole.
Bog on it's own will get a bit thick.
Can you access the back of the hole?
If so fiberglass the hole from behind then a thin layer of bog at the front.
Or rivet a steel section in behind an skim the top.
If Riveting counter sink the holes and punch in a bit so the rivets are below the panel level.
Both will give a beter finish than bog alone.
I need to do the same on an even lager hole in my rear quarter.
Regards
Dean.
A cleverly cut sheet of metal
A hole in the middle and a peice of wire to hold it while you attach and access problem solved.
The hole looks wider than long so you should get it in from the front.
