February 2, 201214 yr comment_581733 Hey guys, did the crow cams find a cam thing and got this back ******* CROW CAMS SELECT PROGRAM ******* 16 COLBERT RD CAMPBELLFIELD 3061 phone (03) 9357 0469 fax (03) 9357 0001 WWW.Crowcams.com.au MODEL TYPE 3K 4K COROLLA ---------------------------CROW COMPUTER CARD---------------------------- | PART NUMBER 600608 Date 30-AUG-11 | | Cam type: Mechanical / Solid type Profile MIN LIFTER DIA.653 | | ----------------------------------------------------------------------| | Advance Ground on Cam: Lobe separation: 107 | | .050 VALVE TIMING | | Inlet opens: 13 BTDC Closes: 47 ABDC .050 Duration: 240 | | Exhaust Opens: 47 BBDC Closes: 13 ATDC .050 Duration: 240 | | ADVERTISED VALVE TIMING | | Inlet opens: 40 BTDC Closes: 74 ABDC ADV Duration: 295 | | Exhaust Opens: 74 BBDC Closes: 40 ATDC ADV Duration: 295 | | Inlet lobe lift at TDC on the over lap:.084 | | ----------------------------------------------------------------------| | Valve lift Inlet: .4118 Inlet Rocker Ratio: 1.50 | | Valve lift Exhaust: .4091 Exhaust Rocker Ratio: 1.50 | | Valve Lash Inlet:.014 Valve Lash Exhaust: .014 | | ----------------------------------------------------------------------| | RECOMENDED VALVE TRAIN COMPONENTS | | Valve Springs: Spring height: Collets: | | Retainers: Pushrod: Lifters: | | H/D Timing Set: | | ----------------------------------------------------------------------| POST CODE These HIGH PERFORMANCE components should be checked for suitabilty by the person installing them as engines of the same group can vary in valve length spring installed height and collet grooves IT THE SOLE RESPONSIBILTY OFF THE INSTALLER TO CHECK SUITABILTY Can anyone tell me what this cam will be like? I have no idea how to read and translate these sort of things :P Also it's listed as a 3k 4k grind? Report
February 2, 201214 yr comment_581745 Where yours says "advertised valve timing 295deg" mine says "270", and where your lift is 0.4118 & 0.4091, mine is 0.3965.... So yours should be quite a sporty high-revving cam. Set the tappets at 14thou like they say, and if you want it revving hgher close them down to 12thou, or a smoother idle open them to 15thou. I found their 16thou recommended gap on mine too wide and the tappets rattled, so I'm running 12thou. Report
