ive heard that i can't use a fwd ae82 alternator belt on a rwd application is this true?
also diff options I'm thinking of buying an lsd ae86 diff for my ke70 do they bolt straight up?
sorry for novice questions i have googled but cannot really find what i want
cheers luke :)
cheers luke :)
The belt isn't the problem; the pulley alignment is the issue. The water pump pulley has a slightly different offset from RWD-FWD versions of the 4AGE engines.
What he said. Also there are two different alternator pulley sizes.
Most likely, assuming your engine is a local AE82 bigport, you will need a 5PK830. If you have a later alternator with the larger pulley, you need a 5PK840.
But yes you need to work out the alignment issues first.
With respect to your diff, search on here.
