Ke70 Wagon Stater Motor Problem
Hi guys I have problem with my ke70 wagon sometimes try to start the ignition didn't kick but the break light is on everytime try to start the car, try to look for starter motor but don't know where the starter motor location, or how to install a new one so can anyone help me out.. also sometimes the engine shakes, I though it was oil pump or maybe the cabie is gone posibily.. it could be anything...
Soo please help
I'be just change the oil yesterday and spark plug so hopefully it will work..
Edited by philbey
..and the problem might not be with the starter motor at all, it could be in the ignition wiring, so don't blow your cash on a new starter until you know.
First sort the brake lights, then have the battery checked, then make sure the key puts power down to the starter every time. The starter is hidden under the exhaust manifold and you get at it from under the car... horrible place!
Find a wiring diagram for the car on the net and check for brittle/burnt wires under the exhaust manifold.
Not the oil pump in a million years! Change the plugs and show us a photo of the gaps in the old ones. Check the points gap and timing, then play with the idle mixture and idle speed screws on the carb. When the motor is warm you should screw the mixture out then in half a turn at a time to get the fastest idle speed, then reset the speed with the idle speed screw.
Make sure there is no water under the oil cap and no oil film in the radiator, & one day check the tappet gaps...
Edited by philbey
Thank you so much for your help should be able to fix this problem tomorrow..
here's a bit of a wiring diagram I was colouring for some project.
Physically the fusible links are under the exhaust manifold, as are the starter wires and the alternator wires. They all get affected by heat and a poor connection will cause them to not work occasionally. I've had to re-solder the contacts on the fusible links and the starter activator.
You could disconnect the ignition key setup under the dash and use a multimeter to measure the resistances as you turn it through its different positions. If it dries out inside or gets burnt contacts it won't power the starter each time.
That is some useful diagram thanks mate.. also couldnt find break fluid to see if need to top up is that normal for 4k engine..
Edited by pro_driver
Yesterday I was stuck in hangry jack had to clutch start the car.. check the battery it work fine.. but today try to start the car after changing few things an it work fine...
Now scared to drive it out on open road just incased broke down again...
