January 18, 200620 yr comment_96610 Ive got a 2E and i wanto find bolt on parts off of a 2ET in order to turbo my lorolla. If anyone knows about a website with specs and info on a 2ET i would like to know more about it. thanks Report
January 19, 200620 yr Author comment_96726 I'm from new zealand and my corolla xl (liftback) has a 2E 1300cc engine in it. I need more power. Do you have any info on the 4E-FTE is it a starlet tubro engine?? and what is a 3ETE Report
January 19, 200620 yr comment_96744 from memory only... someone else can correct or confirm 4E-FTE is from the EP82 (and EP91???) GT starlet 3E-TE is from the GP turbo corolla? Tom (TOMsGPTurbo) should be able to help more than I can... Report
January 21, 200620 yr Author comment_97072 today i picked up a weber downdraught off of a 2.0litre pinto and I'm going to rejet it and make up an adapter plate and see how she runs Report
February 11, 200620 yr comment_101112 since your from NZ, i recommend you visit. starlet central make sure you use the search button and read the tech threads, you sould find all the info you want there on the E series turbo motors. Report
