June 25, 201214 yr comment_612184 i was just wonddering if spacer plates were legal and if so what the maximimum spacing was for QLD. just been having troubles getting front tyres to fit without scraping at full lock. Report
June 25, 201214 yr comment_612191 i was just wonddering if spacer plates were legal and if so what the maximimum spacing was for QLD. just been having troubles getting front tyres to fit without scraping at full lock. 100% illegal. Though I doubt a cop will pull off a wheel. It'll void any insurance. Report
July 19, 201214 yr comment_616360 noob question from a noob guy in melbourne ;) is it true that you are not allowed to lower your car here or the cops will fine you? or is there any limit on how low can you go? sorry for the noob question guys, but no one from my friends can give me the answer :D Report
July 19, 201214 yr comment_616362 The general rule seems to be you can go no lower than 100mm at your cars lowest point. And you can do it as long as its done properly, so no cut springs. Report
July 19, 201214 yr comment_616371 i see, thanks man! its a good thing i found rollaclub.com! cheers! Report
July 19, 201214 yr comment_616372 there are also limits on percentages of suspsension travel, both bump and rebound. ie if you lower the car too much, and only have 10mm of bump travel left, you might be within the 100mm, but not comply with the suspension travel requirements. Report
July 19, 201214 yr comment_616375 Here is a guide from Vic roads, its from 2003 but I'd say its still relevant. http://www.vicroads.vic.gov.au/NR/rdonlyres/CC48FC10-4D57-4F04-82E1-3BD72EF88340/0/VSI8.pdf Report
