  • 4 weeks later...
lol.i just spotted that!pretty much what i did but i used some 2mm alloy plate(for heat deflection)bent it into a semi circle and folded a 5mm lip on the inside top edge and riveted it to the bottom of the bonnet.then using more alloy i made a flat plate to sit on the carby and put ruber edgeing on both so when i close the bonnet it seals but still easy to get to air filter and carby.works brilliant!
26072012447
26072012446
