Since playing with Datsun 1200's for the last 3 weeks I've noticed one thing.... They have the same diff as a KE10. I blew my Datsun diff, and i looked the KE10 diff's i had lying around and they were exactly the same.. Different stud pattern and tailshaft flange.
Quoted from the Datsun Tech wiki " Apparently this is the same diff that was in AMI-built Corolla KE10, but those have a 4 x 110 wheel bolt pattern. "
The Borgwarner Model 60 rear diff... So i'm thinking the people with Borg Warner diffs in their KE10's could potentially unbolt the axles out, and put Datsun 1200 Axles which are 4x114.3 and then put KE20 discs with 30 hubs and have a 4x114.3 conversion for probably around $50-200 depending on how cheap you get the parts....
Somebody should try it. I tried to get my Borgy axle out and it wouldn't come apart so gave up lol!
  • Upvote 1
  • 2 months later...
  • 1 year later...
