1971 Ke25 Coil Ballast Resistor Wiring
te27
Hi , can anyone post a photo of their coil wiring on a 3k motor. I'm a little confused as to which correct wire is ran to the ballast . I have a black/ yellow trace wire which is ran to the + side of the coil. If someone has a unmodified engine bay can they please take a pic of the coil and ballast area. I have a feeling I am missing a wire. I want to keep engine bay original . Or can u SMS a pic to 0424666915 cheers
The black/yellow trace(or orange trace) wire should be +12v, this goes into one side of the ballast resistor. The other side of the ballast resistor goes to the positive terminal on the coil. ie. the ballast resistor goes between the +12v source and the positive on the coil.
Edited by rian
