July 17, 201214 yr comment_616038 Hey guys I have a Ke 30 and I've got a t50 box to go in it and I'm puting a hydraulic clutch in and I'm wondering if anyone has done this before? I'm not sure what master cylinder to use and what's involved in modifying my clutch pedal to suit. All help and photos would be much appreciated. Report
July 17, 201214 yr comment_616040 T50 for what engine? My mate bought a ke55 project with an s14 sr20 in it, And as far as we can tell it has an ae71 pedalbox in it.. But these are highly sought after and expect to pay up to 300 for one.. Report
July 17, 201214 yr comment_616047 TA22 for master cylinder. If you have a look on the firewall near where the clutch cable is, there's two studs - thats where the master cylinder bolts to (just have to drill a hole for the rod to go through. The clutch pedal will have to be modified with a hole for the rod to attach to. Report
July 19, 201214 yr Author comment_616443 It's a T50 for a worked 4K I'll have to look into it do you know what master a slave cylinders I'll need? Report
