February 4, 200620 yr comment_99704 hey guys just wondering if the 20valve can handle say stock t28 boost 9psi with little mods? Report
February 6, 200620 yr comment_100236 yes they can however u wont be happy with the reliability as jason said..... heaps of info out there. but basiclly: rebuild with 4agze pistons and rings fit 3sgte injectors use aftermarket ecu Report
February 12, 200620 yr comment_101307 talk to "Speed Tech" in New Zealand. They have a turbo 20v putting out crazy numbers. Report
February 12, 200620 yr comment_101313 yes but its a pure drag engine they also have some funny ideas like only using 8.0:1 pistons. Report
February 12, 200620 yr comment_101319 When you add up the cost of an ecu, turbo and manifold, intercooler and piping. It makes you think, it would be worth spending the $700 bucks on forged 20V pistons? http://cgi.ebay.com.au/TOYOTA-TURBO-4AGE-2...1QQcmdZViewItem I've heard GZE pistons ping like a bitch in a 20V unless alot of tuning is done. I'm in the process of getting a 4AGTE together, thought about going down the 20V road, but considering I want to run a megasquirt, I figured a Low K gze bottom end would be cheaper to kill than a turbo 20V item. Report
February 12, 200620 yr comment_101361 Thing is though you might want to be able to tune the motor, I want the rings and bearings to be run in. If I got a 100kw bottom end I'd be inclined to get new gze pistons, bigends, mains and rings, which is the plan once I have a good map to play with. Report
February 12, 200620 yr comment_101382 've heard GZE pistons ping like a bitch in a 20V unless alot of tuning is done. thats not true. and youll need tuning no matter how u go about it yes 100kw bottem end is the better start. for the cost of a ze you can buy and rebuild a 100kw bottem end with NEW ze pistons TRD bearings and new gaskets Report
