lokie168 Posted September 17, 2012 Report Posted September 17, 2012 was running at 80 kph and shifted to 5th gear and the speedo suddenly wasn't moving. what could be the reason? btw i have a ke35 with a 4k engine Quote
irokin Posted September 17, 2012 Report Posted September 17, 2012 Chewed out speedo drive gear. They're only nylon and the metal worm will happily destroy them (or could just be worn down enough). Quote
lokie168 Posted September 17, 2012 Author Report Posted September 17, 2012 (edited) would this be costly time wise and money wise? Edited September 17, 2012 by lokie168 Quote
irokin Posted September 17, 2012 Report Posted September 17, 2012 Nope. 10 minutes, one socket size and maybe some multigrips. Quote
irokin Posted September 17, 2012 Report Posted September 17, 2012 Not the same gearbox but it's the same location and setup. Basically unscrew the speedo cable, undo the bolt and you should be able to pull the carrier out. The carrier will have the little nylon gear in it and you should be able to see fairly easily if its buggered. Quote
parrot Posted September 17, 2012 Report Posted September 17, 2012 If you do replace it, you need to ensure you get one with the same number of teeth. Other possibilities include a broken or detached from geearbox speedo cable (remove and check), or the cable has fallen out the back of the speedo (unlikely) Quote
lokie168 Posted September 17, 2012 Author Report Posted September 17, 2012 will try to look at it or bring it to a shop. btw i'm having problems with my car. taking to long to start it. and when it runs it stutters then runs smoothly and then when i go to a full stop for a red light it stutter again then runs smoothly. do i have to correct the timing or just set the points? Quote
lokie168 Posted September 17, 2012 Author Report Posted September 17, 2012 btw it idles smoothly Quote
lokie168 Posted September 18, 2012 Author Report Posted September 18, 2012 solved the stuttering part. now will look into the speedo part. Quote
