Sorry looks like i was wrong again.
The ones i was thinking of are off dads car.....
Oh and clown is the mr2 manual a repair/workshop one?
and does it contain the 4agze?
Part # - No
tell us where i can find it and ill have a looksey.
The part # is printed on the injectors on the side, You had me worried that there was a new breed of injector for a second there, I was looking madly for it the other night..
yair sorry bout that dude, i had dads old ones sitting around somewhere and it seemed like the last thing i saw when i read your post......
anyway, whats the down sides of installing waaaaaayyy to oversized injectors in a 4age? ie 180cc up to 440cc 7m ones?
Someone once told me that the max u want to run you injectors is at ~80% duty cycle?
BTW thats a good faq you got coming along.
You would need an aftermarket ECU and some tuning time on a dyno if you switched to bigger 7MGTE injectors.. It really depends on your setup as to how big you go, You don't want a nice expensive engine you have just rebuilt leaning out..
As for the FAQ, its coming along bit by bit, I keep adding things as I come across them (Mostly 4AGE related info as it relates to my current conversion), Anyone can add stuff in if they learn how to work it and have an article to put up..
yeah, the Big ass toyota manual.
WRX injectors look to fit 4AGE.
i got a pic to but yair after a bit off googling its all confilicting info. I can't get a straight awnser about the size of stockos, but it seems to be either 240cc or 300cc. WRX STI ones are probably around 500cc.
just an idea hmmm.
Went pink injector clip hunting the other day. Found that FWD pre-widebody camry wagon's were the deal. The sedans weren't the same. It is only possible to get 2 clips per spacia, need to pull out the motor to score the other 2.
Got a spare set if anyone is in need.
