September 30, 201214 yr comment_629615 Hey guys just got the 4age running in my ke70 and went for its first short drive yesterday, so it idles fine after we played with the dizzy for a bit but sounds like a wrx under load anyone know what the go is? Also hasinimal power almost like running on 3 cyl. :( van anyone give me some advice on what to check? Report
September 30, 201214 yr comment_629616 You are probably right, that Subaru sound is very 3cyl. Carbs or injectors? The fastest way is time on a dyno as you can measure the electronics one by one under load, check plugs firing, coil, & injectors etc. All it needs is a plug or lead breaking down under load. Start with compression tests, then a "plug cut" check after running it hard in 3rd for 3 or 4 seconds. Check plug lead resistance with a multimeter, but none of these are as good as reading the motor directly under load. Borrow a Megasquirt! Report
September 30, 201214 yr Author comment_629617 Thanks man ill give them a crack today, not sure if map is reading properly either and gotta regap plugs too Report
September 30, 201214 yr comment_629619 This is my bible at the moment (except it contains useful information). Report
September 30, 201214 yr Author comment_629622 Holy shit man that's gold, been looking for a manual for ages cheers Report
