- Starter Motor 4Ac/4Age - T50
Compression Session
So I should do it again with throttle full open? And engine will probly stay in when I do the rings and some other bits, a mate has my crane :( so as lone as within 10 percent comparing highest comp to lowest should be still good, I need to get exhaust done too running factory one from the 4k :D
Compression Session
On bigport? Probly gunna do a ringset and stemseals soonish though to be sure, seems down on power too, doesn't seem to mak power all the way through the revrange, do the butterflies on the tvis stay open or shut when it is disconnected?
Compression Session
Cheers ill give it a crack, I didn't really know what it should be for a 20 something year old engine though haha, need to do rings and valve stem seals anyway I think
Compression Session
Just wanna know what everyones comp tests where the last time you did one? Mine come back as 159.5 psi on three but no.1 was down 12 psi to 147? Bigport 4age question mainly, but throw results up anyway :)
Motorfix Style Gze Ke70
Awesome job man looks great, ʞ©$ɟ the shiny paint lovers, MOTORFIX FTW
4Age Sounds Like A Wrx Under Load
Holy shit man that's gold, been looking for a manual for ages cheers
Thanks man ill give them a crack today, not sure if map is reading properly either and gotta regap plugs too
Hey guys just got the 4age running in my ke70 and went for its first short drive yesterday, so it idles fine after we played with the dizzy for a bit but sounds like a wrx under load anyone know what the go is? Also hasinimal power almost like running on 3 cyl. :( van anyone give me some advice on what to check?
Describe In One Word - When You Went 4Age :d
Ahhhhahahaha oprah, I'm not really expecting it to be fast either to be honest, just, balanced I guess is the best way to describe what I'm after :)
Haha awesome :D they might not he the fastest thing out but are well balanced and slide well with a bit of speed lol I still need to find a tailshaft for mine :(
So I just got my 4age going (in ke70) and just wanna know what your feelings where when you jumped in and drove the 4age car you own :)
Spark Help - I Have Searched
All good there was some randomness going on with the ecu so bought jdm one and it fired straight up :D
Not sure how to put it up on my phone :( diagram says its tacho signal?
Hey guys nearly done in the 4age wiring department, but there is 2 black with red fleck wires coming from the engine side of the ignitor, join tegether and then to a single clip plug, now I don't know what the plug is for and its not plugged into anything, is this reason for no sparky sparky? The wire is a brown one on the ignitor side of the green plug and then turns into the double black with red fleck ones if that helps? Please help, we have tried 2 sets of leads, 2 dizzies, 2 ignitor packs, 3 coils and new plugs,pretty much at the end of what we can do at home here
01sik
