4Age20V Silver Top Into Ke20
I'm looking to do this coonversion. i have the engine (half cut) rwd gearbox. am i going to be over my head with this?
If you don't know what you are doing, then yes, probably.
^^^ Agrees
Shouldn't be hard as above though if you know what you're doing, should be easy to fit. There is someone one here that makes mounts to bolt 4age into a ke20 as well so it is simply a bolt in wire in and the rest of usual engine conversion hassles.
  • 7 months later...
any updates on this?
