Twincam16seca Posted October 28, 2012 Report Share Posted October 28, 2012 (edited) Hi all, My indicators are flashing at irregular speeds intermittently mainly when signaling left. Occasionally it does it when turning right, it will be flashing at a normal speed then speed up, i have noticed it changes only some times when turning right and other times it changes speed without turning the wheel. Just wondering if its my flasher unit or wiring gremlins? :hmm: When the hazard lights are on they both flash at the correct speed and the globes are fine as far as I'm aware, as i have replaced one already! thanks for the help! Edited November 29, 2012 by Twincam16seca Quote Link to comment Share on other sites More sharing options...
Twincam16seca Posted November 12, 2012 Author Report Share Posted November 12, 2012 so no one can help me out then? Quote Link to comment Share on other sites More sharing options...
Twincam16seca Posted November 29, 2012 Author Report Share Posted November 29, 2012 Just an update both indicators were flashing too fast but now the left indicator has mysteriously fixed itself, so this morning i gave the right side a bit of a nudge and nothing happened, so i grabbed the wiring from the back and gave it a wiggle...still nothing, so I gave the loom a pull towards the indicator and it has decided to work, so still no idea what it is/was exactly but they work now! Quote Link to comment Share on other sites More sharing options...
Twincam16seca Posted December 10, 2012 Author Report Share Posted December 10, 2012 the left side has now started flashing fast again, so if anyone can help me before i start pulling everything apart to fix it, it would be appreciated! can't believe no one else has had this problem... Quote Link to comment Share on other sites More sharing options...
Addicted Posted December 15, 2012 Report Share Posted December 15, 2012 if your tugging the wiring near the combo switch and it is upsetting/pleasing the gremlin, is it a combo switch wiring problem/plug. Quote Link to comment Share on other sites More sharing options...
mike100 Posted January 9, 2013 Report Share Posted January 9, 2013 check the indicator relay, or bad earth some where. Quote Link to comment Share on other sites More sharing options...
