Ip Blocked From Faq Editting
My is my IP blocked from the FAQ edit? (141.168.0.45)
I have made heaps of corrections, and want to correct the Torana carby section, the 4cly Starfire are strasbourg's not stromburgs and are very differnt carbys, good performance for K engines as the are performance carby's for 4cly non-cross flow pushrod 2valve-per cly heads, and are suited to 1.2-2.2ltr engines.
So if sum admin could tell me y, id appreciate it, or if someone else wants to make the corrections thats great, i hope u know all the info.
No IP blocks have been set or are listed for the FAQ.
Well thats not what I'm told, when i click EDIT, it says:
Your user name or IP address has been blocked by SORBS DNSBL.
The reason given is this:
Your IP address is listed as an open proxy in the SORBS (http://www.sorbs.net) DNSBL.
You may contact SORBS DNSBL or one of the other administrators to discuss the block. Note that you may not use the "email this user" feature unless you have a valid email address registered in your user preferences. Your IP address is 141.168.0.45. Please include this address in any queries you make.
Return to Main Page.
SORBS DNSBL doesnt exist either...
