December 2, 201213 yr comment_638510 Hi, I recently purchased an '89 SX hatch with 4AGE motor. The car needs a bit of TLC!! One problem is erratic idle. From cold the idle surges between 1500 and 2500 rpm. before slowing after a few minutes but still surging at lower revs. Any help with likely cause/fix would be greatly appreciated. Thanks in advance. Cheers, Dave Report
December 2, 201213 yr comment_638512 Sounds like a vacuum leak, or your throttle position sensor is not adjusted properly. Report
December 3, 201213 yr comment_638520 mine did the same.thing, turnes out to be low coolant level, the idle hunts because the wax pellat doesnt heat up in the throttle body, i think it has been coveredon here before, so maybe search it up top Report
December 3, 201213 yr Author comment_638525 Thanks heaps guys, they are really helpful tips :o) Report
