December 9, 201213 yr comment_639245 I have put a 3k in a ke35 i got from the wreckers everything i have managed to wire up properly except the alternator. It is the externally regulated type and i have found where it plugs into. but i need a section of wiring in between. basically I need to know which pole on the alternator goes to which part of the connector? The male connector that goes into the alternator and the one pictured below are the same size/shape. can I just go off that? and the B+ pole can just go the the positive terminal can't it? Thanks, Ben Report
December 9, 201213 yr comment_639247 http://www.rollaclub.com/wiki/index.php?title=Tech:Engine/K_Series/Alternator Report
