December 21, 201213 yr comment_640699 Hello All, I am going to fix a 7k-e (1.8) engine and would like to know if anyone can help me with the angle I should mount it. I see in pictures that it is mounted at an angle and don't know why. So I greatly appreciate if you could help in letting me know the specific angle I should fix it at. cheers. Report
December 23, 201213 yr comment_640954 most k series motors mount on that angle mate, itll be fine, place it on the factory engine mounts for the car. your putting it into. some cars you will need to mod the sump for clearence. Report
December 25, 201213 yr Author comment_641177 Hello there, Greetings for the season. I am using a 7K-E engine as a mod in a small jeep. I would like to get something clarified. First is what is the redline rpm for this engine? Second is can I fit a turbo to this engine? I was told by some that it cannot be done. Third is How to find a service manual for this engine? I am really needing this information and would really appreciate if anyone can help me. thanks a million... Report
December 25, 201213 yr Author comment_641179 Thanks. I am fixing it with a similar angle. But I am not sure if I got the angle to the exact degree right. A number here would be quite helpful. I have enough clearence for the sump since I am fixing it on a 4x4. Report
December 25, 201213 yr Author comment_641185 Hiya, Will anyone help me to find the power band curves for toyota 7K-E engine please? Desperately need it... thanks! Report
December 25, 201213 yr comment_641186 Hi mate, I merged your topics into one thread seeing as they all seem to be to do with the same engine. Try not to make a new thread for every question. I understand you want answers but making a new topic every few hours wont help :y: Edited December 25, 201213 yr by B.L.Z.BUB Report
December 25, 201213 yr comment_641189 Hasitha you will struggle to find much on that engine as it really is just an industrial unit. With the long stroke it won't rev very high and it has never been regarded as an enthusiast's choice. The compression ratio is 9.1:1, the same as most K motors, so it should take turbocharging OK. Here's the Toyota workshop manual; for it. http://images.toyotakijang.multiply.multiplycontent.com/attachment/0/T79igAooCH0AAFBv5Xs1/Toyota%207K%20Engine%20Repair%20Manual.pdf?key=toyotakijang:journal:31&nmid=560968192 Report
January 14, 201313 yr Author comment_643702 Hello All, Thank you for the comments. I am not much happy about the 7K too but it was a better choice among the once I came across as it had better torque. I am using it in a small suv (something like a suzuki sj 410) which comes with a 48hp 1000cc stock engine. As to the redline rpm, i couldn't find anything so far... too bad as i will be reving this when i get stuck in the mud. For the turbo, the intake and the exhaust is on the same side of the engine. So I guess fixing a turbo is a near impossible?? I have another 2 new issues half way into the project. One is that the sump has to be modified as i have to shift the engine a bit back as the rig is nose heavy. Is there any way to move the oil pick up the back of the oil pan and what are the issues related with it?? The other is that I have fixed the engine in its slanted position when viewed from front and is it possible to lift the nose of the engine (radiator side) to get a bit clearence? This means that the engine would be at an angle when viewd from side (standing next to the fender)? Any help and advice is very much welcome... Thanks a million! Report
