It will bolt straight in with a te2# engine crossmember and engine mounts. :)
Plus you will either need to find a forward selector t50 or extend you shifter hole in the driveshaft tunel closer to the hand brake to acomidate the rear selector t50.
The standard ke2# gearbox crossmember is the same as te2# and bolts further back in the chassis rails so no mods there.
