Howdy, does anyone know the torque settings for Ke35 front hubs, the bolt that holds it onto the spindle and also the four bolts that hold the disc on? Search came up nill and I don't have a workshop manual yet.
Many Thanks
Disc to hub 55Nm or F, tight.
The hub nut has to be done up so that its not tight or youll do your bearings in no time.
But not loose so the hub moves when you shake it.
Do it up firm then back it off so it spins free.
Add new split pin .
