nos399 Posted July 30, 2013 Report Share Posted July 30, 2013 (edited) Hi.. I want to know improvement 4K silent start engine but start sound it Disturb Neighbor Unknown Coil start or Distart Problems in all LPG Use because in a every Morning cool air ,engine start it hard and long time (2-3 rounds) in use Standard Spark plug (Denso) and Standard Wire Spark plug (Toyota) Please support me Thankyou. Edited July 30, 2013 by nos399 Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted July 30, 2013 Report Share Posted July 30, 2013 (edited) To make it all very clear.. The motor noise it makes is quite normal, but you want the motor to start faster?? ...and it is probably your choke problem that makes it hard to start on a cold morning. Edited July 30, 2013 by altezzaclub Quote Link to comment Share on other sites More sharing options...
CREEDY Posted July 30, 2013 Report Share Posted July 30, 2013 If it's running on lpg it's going to take longer to start Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted July 30, 2013 Report Share Posted July 30, 2013 Any way to richen it Creedy? Hit it with an "Engine-start" aerosol first?? Quote Link to comment Share on other sites More sharing options...
Banjo Posted July 30, 2013 Report Share Posted July 30, 2013 (edited) Where abouts are you located, and when you say the mornings are cool, how cool are they ? What is the temperature in deg C ? A good squirt of "Start Yu Barstard" will probably solve the problem. Cheers Banjo Edited July 30, 2013 by Banjo Quote Link to comment Share on other sites More sharing options...
CREEDY Posted August 3, 2013 Report Share Posted August 3, 2013 If its lpg maybe try priming it twice(like glowing a diesel) or if the regulator is manual prime then it makes things a bit more tricky. Quote Link to comment Share on other sites More sharing options...
