September 7, 201313 yr comment_666448 Hi all can anyone tell me what the valve clearance is for a 3K i hot a new cam in it and the clearances ive been given still tick like a bugga. Just chasing the standard clerances, so can get her running overrated Report
September 7, 201313 yr comment_666450 http://vintage.mitchell1.com/PClubData/chassis/enis78/V2I785266.pdf Report
September 7, 201313 yr comment_666466 My Crow cam came with 16thou specs, and as you've found it was very noisy. I'm running 10 & 12 now, I don't think it is really crucial unless you're racing the car and the gap can be used to adjust the cam timing then, so long as there is a gap when its hot. One tappet is still noisy, I'm sure the rocker is worn away to a groove, its impossible to find without stripping it. Report
