Not sure if i am to post in this section but my cars CHG light stays on and idles good.then i pull my handbrake lever up and the car idles rough and eventually dies.....unless choke is up...is this elec or something else
TIA
Auto box in gear?? or in neutral?
The charge light suggests the alternator is not charging so the battery will run flat. You might fix that first.
However the handbrake shouldn't affect the idle at all.
