When changing to reground cams and also facing the head, what options are there with pushrods?
Seems on regrinds that the base circle is reduced and so longer rods are needed, shaving the head shortens the required rod length...
Have heard something about datsun a12 rods or machining down rocker towers to suit...
Is there a preference with either of the above concerning geometry?
Thoughts?
Edited by styler
Else if cam blanks are available at a reasonable cost, that may be the go?
billets haven't been available for close to 15 years.
There should be more than enough adjustment in the rockers to take up the slack of what is taken off the base circle of the cam.
After skimming the head and doing the cam, shouldn't you be able to adjust the rest of it via the rocker tower heights? You'll need to bolt it all up and check out how the rocker wipes the top of the valve. You should then be able to fix it by either shaving or shimming the towers.
