Kirill Posted November 20, 2013 Report Share Posted November 20, 2013 Hey guys, Got a Ke55 with stok 4K. It has a problem with acceleration while on primary throat. Its not smooth and jerks around and farts a bit then once the secondaries kick in all good to the redline. I took the carb apart and cleaned it all out, blew out the passages and the jets as much as i could, fitted new float valve, some new gaskets etc. still does it. Any ideas welcome. Thanks Quote Link to comment Share on other sites More sharing options...
Mechanical Sympathy Posted November 20, 2013 Report Share Posted November 20, 2013 Have you put a timing light on it to confirm the vacuum advance on your distributor is plumbed and working correctly? Quote Link to comment Share on other sites More sharing options...
Kirill Posted November 22, 2013 Author Report Share Posted November 22, 2013 set the points gap, and replaced the coil, seems to be a lot better thanks Quote Link to comment Share on other sites More sharing options...
