December 10, 201312 yr comment_673392 Hi all, Found a complete silvertop 20V 4AGE with loom, ECU and 5 speed RWD gearbox and bellhousing to suit. No clutch, crossmembers or dizzy relocation setup. Assuming it runs well, whats it worth? I have bigport 4age with T50 gearbox currently installed and running well in AE71 club car used on dirt. Is it worth the drama to upgrade? Cheers Report
December 10, 201312 yr comment_673418 More power is always worth it, but the stock ecu will be no good to you, you need to run an aftermarket ecu and use a map sensor to enable dropping of the airbox. Report
December 11, 201312 yr Author comment_673458 It has AFM included in loom... Use with custom airbox and I can use standard ECU? Report
December 11, 201312 yr Author comment_673466 Ah yes that is true.. Think I'll stick with the BP for now. Report
