February 11, 201412 yr comment_677324 Hey RC, I'm going to look at a 2004 Corolla ZZE122 tomorrow that I might buy and I was wondering if there is any way check if it has any error codes. Does this model have any kind of on-board diagnostics, like OBD2? As I can get an OBD2 scanner easily. Also, if any of you own a ZZE122 Corolla, is there anything in particular that I should look out for when checking out the car? Cheers, Rian. Edited February 11, 201412 yr by rian Report
February 11, 201412 yr comment_677340 We need Hiro up in this thread. Maybe if we say his name three times.... Report
February 12, 201412 yr comment_677358 Not an AE102, don't care :P ZZE122 will be Toyota's annoying OBDII-but-not-OBDII diag setup, so you can't use the old OBD paperclip-between-TE1-and-E1, nor will most generic OBDII scanners work. Try THIS Report
