hi everyone I have a 96 corolla with a 2e engine now I have been trying to get power to the interior lights, when I checked the fuse under the hood in jb2 it was blown so it was changed, now however with that fuse in the rad fans and a/c fan run without the key in the ignition or the engine running.can anyone help? I don't have a wiring diagram for his car but I did change the fan relay at the same time.
thanks guys all I did was replace the old relay I didn't change any of the wiring though perhaps that was done before, would a faulty temperature sensor do this without the engine running?
No I don't reckon that's it.
As Reed suggested you may have bought the wrong kind of relay i.e. Normally Closed instead of Normally Open if you've plugged the wiring into like-for-like.
Or possibly - if you've run your own wiring (edit: you didn't) or you plugged them in wrong - you may have wired it straight to the battery instead of an "ignition on" circuit.
Edited by Mechanical Sympathy
thanks MS
I am jut puzzled a to how the fuse for the dome light has anything to do with the circuit for he rad and ac fans if I ad a wiring diagram it would help. and it is possible they sold me the wrong relay
