June 1, 201412 yr comment_683567 Has anyone fitted 15x8 0 to a ke55? Ciuld you post pics if so. Cheers Report
June 2, 201412 yr comment_683578 They will fit on rear no problem, front is a no unless you rage the front guards and run 155 tyres. Report
June 2, 201412 yr comment_683592 Check out Shiryo's old ride, I reckon he nailed it. http://www.rollaclub.com/board/topic/68433-shirobozu-ke30-for-sale/ You'd need camber adjustment to tuck the fronts though. Edited June 2, 201412 yr by B.L.Z.BUB Report
June 2, 201412 yr Author comment_683596 Your right mate he absolutly nailed it. Now noob question 14x7.5-9 does that stand for negative 9?? Report
June 2, 201412 yr comment_683599 Yep, which would make them sit around the same as 15x8 zero but being 14's they'd tuck easier. Correct tyre choice and camber with lipped/rolled guards. Report
June 2, 201412 yr Author comment_683604 You sound very onto it Tyler. So 15x8zero a no go for sure? Report
June 2, 201412 yr comment_683611 You can make it work, you can make anything work. It just depends on whet you want the end result to look like. I don't know too much about the fron tof the 30/55's unfortunately when it comes to wheel offset. Report
June 2, 201412 yr Author comment_683614 All good mate. I'm new too corollas just brought a ke55. Report
June 2, 201412 yr Author comment_683617 Yea old lady had it 33 years always garaged and 135,000. Love driving it Edited June 2, 201412 yr by benno12 Report
June 2, 201412 yr comment_683618 Start a build thread when you get stuck in to it :y: Edited June 2, 201412 yr by B.L.Z.BUB Report
