Disk Brake T-Series.
Looking at converting my ae86 to disk rear. Running a zenki t,series drum ATM.Anybody have a bolt on conversion they wanna sell me? Or a t series zenki disk housing. I don't really want to fork out $1,500 for the k sport conversion.
Don't want to cut & weld my diff as I can use it in other projects.
I have a st141 diff with brakes. They didn't fit :(
St141 caliper bracket on my t series
Live axle. I'm pretty sure it's a f series.
You will need a st141 live axle as the irs disc set up is completely different.It is straight bolt up the only thing is you need longer bolts to hold the axle and new wheel bearings.
If you find one get every thing including rear handbrake cables and most important the AXLES as you will have to use the st141 axle retaining plates.
Hence you need to remove the wheel bearings to fit them.
Every think else bolts up ,note that 13 inch wheels don't fit 14 is the min.
rob
The bearing spacer they talk about is a small ring on the axle retainer,which the t series doent have but the st141 axle retainers do.
You could get some machined up and weld on to the t series retainers ,but why reinvent the wheel.
Jake you might want check what diff you have,because they do bolt up.
Not sure on shock mount may have to be moved mine was on ke55 so no trouble with shock mounts.
rob
Edited by corollaart
Not the best picture, although you should get an idea of what's going on
