madrolla68 Posted April 6, 2006 Report Posted April 6, 2006 Ok so who knows who the K series head porting gods are , i want too send both my 5K heads to get ported one with bigger valves and the other with STD valves. Quote
madrolla68 Posted April 6, 2006 Author Report Posted April 6, 2006 (edited) Frawley Engines at Redcliffe edit : Then I remembered ur in Perth Hey nick i don't mind ill send the stuff over there if i have too,if you reckon they know there shit. Hey urgent question is compression height of the piston measured from the centre of the pin or from the pin bore,I'm trying to order some custom pistons,also does anybody know what the std rod length is for the 4/5K.might be able tto match up some h beams rods to suit. Edited April 6, 2006 by madrolla68 Quote
madrolla68 Posted April 27, 2006 Author Report Posted April 27, 2006 Hey nick i don't mind ill send the stuff over there if i have too,if you reckon they know there shit. Hey urgent question is compression height of the piston measured from the centre of the pin or from the pin bore,I'm trying to order some custom pistons,also does anybody know what the std rod length is for the 4/5K.might be able tto match up some h beams rods to suit. Ok heres the go,i am having trouble finding someone to do my head flowing so i have decided to purchase a flow bench and do it myself. Yes i know what i am doing just don't have access to the flow bench to test my designs so now i will. I will be doing cyl heads for other people but want to master this machine before i commit to customer jobs. Matt Quote
Felix Posted April 27, 2006 Report Posted April 27, 2006 nice. what sort of flowbench are you looking at getting, or are you going to build your own? Quote
madrolla68 Posted April 27, 2006 Author Report Posted April 27, 2006 nice. what sort of flowbench are you looking at getting, or are you going to build your own? CYLINDER HEAD FLOW BENCH ,,BRAND CLO FLOW ,,MADE IN USA NOT TIAWAN VERY GOOD MACHINE FLOW TO 250 CFM AT 1 INCH TO 30 INCHES ..WILL FLOW HEADS COMES WITH CLEAR PERSPEX HEAD STANDS+CYLINDER SIZES TO SUIT MOST CARS CHEV HOLDEN FORD CHRYSLER AND MOST JAP CARS ,,ALSO CAN FLOW EXHAUSTS +CARBIES +MANIFOLDS+TURBOS+MUFFLERS,,,,,,,,ALSO HAS PITOT TO FIND SLOW SPOTS IN CHAMBER AND PORTS,,THIS MACHINE HAS ONLY DONE 35 HRS WORK Felix this is the one,looking forward to getting it and producing some good results for people at realistic prices. Quote
