October 17, 201412 yr comment_689574 KE15 - what other diff housings fit . Had a bit of a search , heard that (120y -- early ke20 jap ) fit . But what else have people fitted under the rear to the original springs ? I am really after something cheap (no suprise there) . but I have a 2nd KE15 with std springs but no diff housing. Just need it so I can move the car around when required. But I may put a 4age in it down the track and something a bit stronger would be required. Report
October 19, 201412 yr Author comment_689679 So no one has changed to a different rear end in to a early KE10,11,15 ,16 ,17 ? SO NO WONDER i CAN,T FIND ANY INFO ! Report
October 20, 201412 yr comment_689681 I would say that plenty of people have changed the diff in formentinoed cars. But if you are looking for an bolt in upgrade, i suspect such a thing doesnt exist. If you are consierating a 4age or a diff upgrade in general, to make it worthwhile what you want is an LSD, and unfortunately there arent any readily available LSDs available for any of the corolla diffs. I think you would want to start thinking outside the box which will require some fabrication (moving/making spring mounts and a custom tailshaft). Potential candidates are the T series diff from a toyota T18 or JDM ae86. or perhaps a european diff, escort or something. your big issue is going to be width though, as the ke10 series of cars are quite skinny, so you are then looking at a shortening of the diff housing....the dollar$ are starting to add up FAST! Report
October 20, 201412 yr comment_689695 If you just need to move it around, just bolt a ke2x axle in place. I am not aware of anything stronger that bolts in. I have a spare Te27 diff I am vaguely thinking I may bolt in one day , but haven't measured it up. I expect it will be a little wider. You could just use a TA22 diff and cut it down/ weld on mounts etc which would give you a 6.7 T series That still won't be cheap though Report
