SM Hunter Posted February 1, 2015 Report Share Posted February 1, 2015 Hey, i have just rebuilt the head and swapped the cam in my KE20.. it wont even try to fire, its just dead so I'm thinking ignition How do you set the ignition after a Rebuild? iv been trying to set it based on cylinder No.1 ... when the inlet valve goes down and then up again, then the mark on the cam cover and crank almost line up and i get a spark... ( it sparks between 5-10 degreess before tdc..) what could be wrong? I'm thinking this is correct but i don't know a damn shi* about ignition systems Quote Link to comment Share on other sites More sharing options...
ke70dave Posted February 1, 2015 Report Share Posted February 1, 2015 Got any compression? I assume you did the valve clearances? Quote Link to comment Share on other sites More sharing options...
SM Hunter Posted February 1, 2015 Author Report Share Posted February 1, 2015 yeah i had comression, valves is sorted, forced dad to take a trip to the garage after a bit he found out the ignition breaker points where a bit to large... its now runing :D Quote Link to comment Share on other sites More sharing options...
